Old 12-09-2002, 03:36 PM
terry lee's Avatar
terry lee terry lee is offline
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
Let me see? If you take a 427 FE it is considered a BB right?
Bore it .30 over, still a BB.
Now replace standard crank with a 428 and you have a 454 stroker. Still called a BB, right?
Take a 429, 460, etc. they are BB too, right?
Add a stroker and get 514. What do we all this, a BIG BB?
Now enter the new alum. blocks made by Raceparts, not really a Winsor, and not a FE. With the right guts it produces 427ci.
A 9.5 deck height block will produce 454ci with bigger crank.
The new block is about 37 years advanced in technology and weighs alot less than any FE.
In my book, a 427ci is a 427ci engine; and a 454ci is a 454ci engine no matter which way you slice the pie.
The quetion is: Should a 427 new block build be referred to as a "small block engine," or a "little big block engine," or maybe just a "427" ?
Go for it guys.
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
