Old 12-09-2002, 04:06 PM
terry lee's Avatar
terry lee terry lee is offline
GEAR GRINDER CUM LAUDE
Cobra Make, Engine: SPF #1560 w/ Ford Racing [RDI/AFR/RPM] Alum. 427CI - 575HP & TKO
Bannon,
Car was ordered from Doug Reed (Superformance South) in New Orleans back in July. Right now I have the standard 3.73 rear gears, but may opt for 3.55 or maybe as far as a 3.08. All depends how 528 lb/ft of torque hook up with the pavement as to which way I go with rear gears. We need to do aliitle field testing for this setup. I wanted to use 305 tires, but they seem to be hard to find, or should I say replace. For the track, it's going to be slicks on all 4 corners mounted on the original 15" rims. When I do this I will go to the 17" wheels for street use, and then its going to be the same question on tires.
TL
BOYZ and TOYZ
With every day I grow alittle older -
BUT, I'LL NEVER GROW UP!
