Old 12-10-2002, 08:00 AM
kountzecobra's Avatar
kountzecobra kountzecobra is offline
Popeye, good to hear from you. Most all disc brake kits (front and rear) will increase the track width, but by how much depends on the mfg. Which kit are you using? You may want to get in touch with the mfg. and they should be able to give you a dimension. The increase should be the difference in the thickness of the drum vs. the hat thickness of the disc where it fits over the axle flange. I think my track increased by about 3/16" per side.
David Shelton
Lone Star Gashole!
