Old 12-17-2002, 02:19 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
j, sounds like the pivot ball may have come loose and fell out . The fork will have a little play front to back but definitley not up and down. At the opposite end of the fork you will see 2 spring clips that slide over the pivot ball. If the fork has come off or the ball fell out then this would cause the problem. The only other attachment on the fork is to the throwout bearing. If the bearing broke you would have heard lots of noise. More than likely the ball.
Don
