Old 12-18-2002, 08:58 AM
Tom Wells's Avatar
Tom Wells Tom Wells is offline
Default Uh oh...
Hi David,
Sounds like it's trying to tell you something
Pull it apart and let us know what it looks like.
You may want to go to The Butcher's web site or at least read my threads on my 460/distributor gear problems in this (460) conference.
It may be that the hole is drilled in the wrong place in the gear/distributor shaft to position the gear properly, or you may get bit for a cam, too if it has damaged the cam's gear
There are a number of reasons why this could happen, so read up on it and post what you find when you pull it apart.
Start a new thread for it so it'll be more obvious, and maybe others will chime in too.
Good luck with it,
Tom
