Old 12-19-2002, 09:17 PM
KobraKarl's Avatar
KobraKarl KobraKarl is offline
jeez ,i dont like the sound of stacked washers being used to compensate for clutch adjustment!! is it cable operated or hydralic slave? ,you may need a longer actuator-rod( between fork and slave cylinder) or relocate slave. 5 washers under a bolt securing somthing as labor intensive as your clutch fork will allow that bolt to continuously flex, even a grade 8 will fatigue eventually ,this could be a good time to get it right good luck with her Karl
Foolish consistancy is the hobgoblin of tiny minds
