Old 12-20-2002, 07:37 AM
Wayne Maybury's Avatar
Wayne Maybury Wayne Maybury is offline
Canadian Gashole
Cobra Make, Engine: Johnex 427 S/C, 351W, 472 HP, 444 lbs. torque
Question Line Lock Question
I am in the process of installing a line lock. The unit itself is now mounted and the brake lines attached. The only thing left to do is to run the electrical connections. I want to use a switch, not a push button since I would like to be able to use the line lock to hold the car when stopped on a hill, at a red light for example.
Now for the question. For those of you that have a line lock, where did you mount the switch? On the shifter? On the dash? Somewhere else? What are the pros and cons of each location? I don't want to change my mind about the location after I drill some holes.
Wayne
Don't get caught dead, sitting on your seat belt.
