Thread: Carb Size
Old 12-23-2002, 05:25 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
The way to see what is happening is to measure and look at intake manifold vacuum. If, at high revs and wide open throttle, you still have more than, say, 1-2" of vacuum, then your carb and/or filter is strangling the airflow.
So buy/borrow a reasonable quality vacuum guage, and tee it into a port on a manifold runner (not on the carb) and see what's what.
Once you have sorted that, then you should go get your carb set up properly. 750cfm carb on a "stock" 428 should be OK.
Wilf
