Chris,
I'm running a Johnex with exactly the same set up. Its a FOX based suspension with a Versace Rear end. My trailing arms were made by Johnex and the uppers are standard Mustang. I'm removing them and going to adjustable uppers this winter. This will enable me to change the pinion angle if needed. I'm getting rid of the HEAVY Lincoln brakes and calipers in favor of Wilwood's. IF you plan on Drag racing you'd better forget the TracLoc posi system as it won't last very long. I went to a PowerTrax center section.
Regards,
Bob
Johnex Cobra, Buick V6
