Old 12-26-2002, 09:23 AM
justa6 justa6 is offline
Default Scratch
Wilwood does make a kit for that rear. However, it has the emergency brake built in also and is relatively expensive. But it must save a ton of weight. I'm probably going to do that along with the front end using either a Wilwood or Baer set up up front. I switched to 95 Mustang spindles so I have a lot more options.
Are you running a Trac Loc in your 9". If so, as I said, don't plan on it living very long if your Drag race with slicks.
Regards,
Bob
Johnex Cobra, Buick V6
