Old 12-26-2002, 01:38 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Yes, it is effectively the same as opening the throttle blades a tiny bit more.
You are likely idling too rich as well. That cam might want drilled throttle blades on the primary side.
