Old 12-26-2002, 11:34 PM
decooney's Avatar
decooney decooney is offline
Default Re:
Mustangmendez,
Sorry to hear about the trouble... people/companies like that won't stay in business for long selling junk with boards like this out here. I almost ordered parts from Speedway once, I won't now.
Also, if those upper control arms require Chrysler type screw-in ball joints, when you flip them upside down and reverse them, sometimes the side of the ball joint will "hit" the round end edge/cup of the control arm where the ball joint mounts in to. You can check this with the shocks/springs out and by moving the suspension up and down full/top to full/bottom to make sure its not hitting. Also, the geometry will be way off if you flip them around like this. If all else fails, just send them the parts back anyhow, and demand a refund in writing stating "parts do not fit". If they don't refund you, usually a complaint/phone call to a local business Beaureau official can get things turned around. Good Luck.
Duane
