Old 01-07-2003, 03:19 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
Joe, I'm betting it's the starter...but check the cables first (unless you can borrow a replacement starter for a trial) by doing this:
get some good jumper cables, recreate the condition at your garage, and hook up one jumper cable from battery negative post to engine block...try it; if no change, try putting on a cable from the positive battery post to the starter (or maybe the solenoid if it is firewall mounted), try that; if no change, put on both cables; no change, it is almost certainly the starter...
Good luck, keep us posted.
Ken
