Old 01-07-2003, 02:37 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
HOT START
Remove coil wire and crank engine. If this helps, you have too much initial spark advance.
Then you can try swapping starters. You may need to try several to get one with the grunt.
This is a common problem on small block cobras. It has several causes however. It is more common on motors with more than 10:1 compression. Check your ground cables as well. Do a load test on the battery if you can.
