Old 01-08-2003, 01:19 AM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
Ron:
Hard anodizing is a case hardening treatment to make the outer surface harder where wear resistant properties are desired.
Clear is similar to paint. Protects the surface a little, basically cosmetic. Wont oxidize as quick as raw aluminum.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
