Old 01-11-2003, 05:41 AM
Jim Werth Jim Werth is offline
Cobra Make, Engine: B+B 351w #112
I just set the door panel against the door and moved it back and forth just enough to scratch the paint. Marked the spots and drilled the holes. Checked and rechecked alignment after each hole. I dont remember what size I used but it was pretty big. Somewhere around a 1/2 inch bit. If you make them too small good luck getting the panel off if you ever want to again. The clip will tear out of the panel befor it comes out of the door. Jim
