Thread: Steering Rack
Old 01-18-2003, 08:49 PM
mr0077 mr0077 is offline
Cobra Make, Engine: ERA 427 SO
Default Steering Rack
Bob, is there an adjustment for the axial runout on the steering rack you provide? My rack appears to have a fair amount (>1/8")of in/out play at the input shaft...when turning right the input shaft moves outward at the rack , and pushes the steering shaft and wheel out toward the driver enough that the turn signal won't cancel; when turning left it moves the wheel in so that the wheel hub drags on the turn switch and will actually turn on the left blinker. The gap between the wheel hub and the turn signal assy. changes as the steering wheel goes from full right to full left lock. Ever run into this problem? Is there another adjustment I'm missing that will keep the axial shaft movement at the rack from pushing or pulling on the steering shaft(s)? Any way to limit the movement at the rack?
Thanks in advance.
Ken
