Old 01-20-2003, 08:23 PM
bigmike bigmike is offline
Default Aluminum envy vs. TSR
Yes, Yes, David K. et al do make a most desirable toy.....
HOWEVER;
Having been recently separated from gainfull employment (unwillingly), all I can do is enjoy my TSR (Tupperware Street Rod).
Actually, I'm not doing much enjoying, as my original CJ heads started shedding cast iron pieces into my cylinders. Result: destroyed pistons, damaged bores, and bent valves. Not bad after 300 miles of running, no?
I am currently starting over on the 428 CJ... should be up and running in about a month.
Someday, when $$$ flow again, I will make the journey south (about 30 miles) to visit KMC and re-ignite my aluminum envy. In the meantime, anybody need a mechanical engineer with 27 years experience?
BigMike
