Old 01-21-2003, 04:54 AM
Mike Hausner Mike Hausner is offline
Club Cobra Member
Cobra Make, Engine: CLASSIC ROADSTERS 427 with a FORD 5.0 bored and stroked to 331cid, BRODIX alum heads, roller rockers, B303 cam.
The Ford 302 has the oil pump in the front of the engine, and using a front sump pan means you have a shorter distance from the pickup to the pump. The CANTON road race pan should come with a new pickup designed to work with the front sump setup and has baffles to keep the oil in the sump area. The RR pan takes 9 qts of oil, you will have to re-calibrate your dip stick just to be sure. The only other thing to check is to be sure the pump isn't sucking air from above the oil level. Let us know how you make out...............MH
