Old 01-21-2003, 09:21 AM
Ross Murray Ross Murray is offline
Default What block do I have
I have found a 427 SO block, but need some help identifing it. It is a SO block (it has the hump) but it was never drilled. There are pilot marks were it would have been drilled. It is also cross bolted and has an oil supply for hydralic lifters. The SO hump has been partially machined away on the lower portion, about 1 inch. The only numbers I could find were stamped and were 8OL, I assume it starts with a C but was missed.
Any thoughts on what I have found would be appreciated.
He is selling this as a complete motor with the following:
Block is .017
Crank is iron .010/.010
Rods are CJ Cap screw style
Pistons are KB Hypereutectics
Heads CJ's w/ 427 ex valve new springs
Offy 2X4 or Ford Single 4 Intake with carb/s
Rebuilt Wide Ratio Toploader
asking $6200
Is this a reasonable price for the above?
Thanks, Ross
