Old 01-24-2003, 01:57 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
There is a gold irridited sleeve on the column which has the detents for the turn signal. It is behind the steering wheel hub. You gotta remove the big nut to see it. Make sure it is clocked correctly. Other than that, you can try replacing the arm assembly, it is a VW part, try your local vintage VW store. (I am thinking 73 superbeetle)
