Old 01-27-2003, 05:17 AM
Hank Dondero Hank Dondero is offline
Default R3S03s
I have to echo the responses so far regarding the R3S03s. I found that once warmed, and properly inflated, throttle modulation will allow you to "steer" with confidence and accuracy. Only time I felt the tires to be squirmy was when they where hot in very hot track temps. Sidewall flex would increase. (Running 22 lbs front, 23 lbs rear cold).
Great tires that last quite a while on our light cars.
Hank
FFR 1776-II
