Old 01-27-2003, 08:28 AM
427 S/O's Avatar
427 S/O 427 S/O is offline
I beat the accusump system with a Weldon pump 9200-A, I tapped into the oil pan, through the pump on to a filter, then a check valve, and on to the front side oiler plug. Works much better than accusump, pumps up to 40lbs for as long as the switch is on, also installed a low pressure switch that activates the pump, NASCAR uses this pump to cool rear end dope.
Perry
