Old 01-27-2003, 03:56 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Doesn't the C-6 use the same speedo cable as a toploader? If it does, then it is a direct bolt-in part. Replaces the speedo cable with an electric sender and it's cable. I only put one electric speedo in a cobra, it went into tremec. The tremec needed a tiny bit of work with a die grinder to give the adapter room to sit in place. best guess
