  #25 (permalink)
Old 01-27-2003, 06:37 PM
a427sc a427sc is offline
Scott
The TD's are a harder compound than the Goodyears. The softer tires will build more heat faster, thus the softer initial PSI. The "real" slicks also use a stiffer sidewall, so less pressure needed to hold the contact patch.
Are you gonning to come play with us at BeaverRun?
Don
