01-30-2003, 06:55 PM
Administrator
Wa
What about something like Por 15's Glisten PC or Prelucid?
http://www.porshop.com/porshoptop.html
Pelucid - Rock-Hard Clear Coat - Half Pint
Add tough, incredibly 'deep' clear luster to most any surface with all-new PELUCID™. Pelucid™ is super clear, super glossy, and unbelievably tough! Use it on painted or unpainted steel, fiberglass, wood, and many other surfaces that need a clear luster finish. This tough yet flexible coating dries to a clear-as-water, rock-hard finish that won't crack, chip, peel, or yellow in sunlight, and is actually strengthened by exposure to moisture, rather than weakened like most coatings.
1/2 Pint covers @ 25 Sq. Ft.
Pint covers @ 50 Sq. Ft.
Quart covers @ 100 Sq. Ft.
Pelucid - Rock-Hard Clear Coat - Half Pint Pelucid - Half Pint$14.00
Pelucid - Rock-Hard Clear Coat - Pint Pelucid - Pint$22.00
Pelucid - Rock-Hard Clear Coat - Quart Pelucid - Quart$38.00
Pelucid - Rock-Hard Clear Coat - Gallon Pelucid - Gallon $140.00
Glisten PC - Pint
A Brilliant Two-Component Clear Coating, GLISTEN PC™ is a High Gloss, Rock Hard, Water-clear topcoat designed for spray or brush application over all metal surfaces, including highly polished aluminum and chrome surfaces. Glisten PC will not leave brushmarks, and will dry in less than one hour, but will take 3-4 days to reach maximum hardness.
When Glisten PC is first dry to the touch, it will appear to be very soft. Avoid touching it for several days until it becomes hard and tough. Accidental contact could damage the surface before full cure has taken place. Like many other coatings, Glisten PC is a MOISTURE-CURED coating, which means it is strengthened by exposure to moisture. It will never crack, chip, peel, or yellow, and is very flexible as well.
IDEAL USES: As a protective coating on aluminum wheels, chrome bumpers, marine railings, chrome or aluminum covers, grills, handles, ornaments, lights, etc.
