Old 01-30-2003, 10:56 PM
Turk's Avatar
Turk Turk is offline
Cobra Make, Engine: What Cobra?
Send a message via Yahoo to Turk
I know very little about welding or cracks... but
If a 427 Sideoiler block that does NOT have a crack can be had for $4500.00 and the block with a crack cost $1500.00 you save a total of $3000.00 less the cost of the repairs.
Let's say you saved $2500.00 total.
Considering the parts installed in either block and the cost of machining, balancing etc is another $20,000 Would you want a engine that is well over $20,000 with a crack that has been repaired or spend the additonal amount to do it in a block that is healthier.
Intake, carb(s), crank, pistons, rings, heads are going to cost you the same.. Do you really want to take a chance all for what, to save $2500?
I wouldn't. I would be more inclined to put in a Non Sideoiler engine, maybe even a 428 before I take that risk.
TURK
OBAMA IN in 2012
