Thread: Body Mounting
Old 02-02-2003, 01:06 PM
scratch scratch is offline
Brushie,
...easy to do, I built mine with the same approach, bought a Hi-Tech fiberglass body and built a tube frame under it.
Besides the four penetrations for bumpers, you will want to hold on to the "skin" as many places as possible...with rubber isolators to keep the stiff frame from stress cracking the fiberglass.
On my frame I supported the body thru;
2 (left & right) under the door kick plates...down to outriggers
2 pads (l&r) (built up polyester areas) under front fenders to frt frame area
3 pads (left, center, right) across the rear fenders to rear bulkhead.
3 pads (left, center, right) across the windshield area to front bulkhead, or firewall.
Both 3 pad areas were rubber attached to the front and reat bulkheads, which attached to the frame. this gives a "cradle-support" across the mid-area of the body..
Don't let the windshield touch the body, go directly to the frame.
Have had no problems with this approach, lets' the glass move a bit over bad bumps.
I didn't want to "glass in" my body to the frame, as I wanted the ability to remove it later if necessary. Otherwise you could just glass everything down to the frame but better disperse the load over a large area.
Good luck and let me know if you want photos.
scratch
