Old 02-05-2003, 04:31 PM
KobraKarl's Avatar
KobraKarl KobraKarl is offline
Zimmy,
cranks for an early top oiler are almost identical to390 crank(both are cast), same goes for rods.
390 pistons would never fit in a 427 block , the bore for a 390 is.18 smaller.
check your block for casting # pasenger side on # 1 cylinder
check your head casting # as well
I have recieved an education on low rise / mid rise manifolds on this forum recently and have discovered just how badly these bolt on parts can be mis-matched, your ida's may not like your low rise heads at all, also manifold and /or carb. air leaks call for a rich tune, that will never run right .
let us know what you find ,you might be better off than you think.
Karl
Foolish consistancy is the hobgoblin of tiny minds
