Old 02-06-2003, 11:10 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
There is no interference at all. I have had my MSD dist and the expansion tank mounted with the inlet port located on both the drivers side and the passenger side without any problem. When you order your distributor be sure and order a steel distributor gear. Also, I understand the Ready to Run distributor is available now for the FE engine. I used this set up on my small block and Bereally liked it. You will also need to change out the springs on the advance that is shipped on your distributor. MSD will send you three other sets of springs so use the lightest ones so your distributors advance will come in correctly.
If you have any other questions just let us know.
Clois
"Let's roll"
"Be part of Something Good
