Old 02-06-2003, 01:49 PM
snakebit31's Avatar
snakebit31 snakebit31 is offline
Cobra Make, Engine: FFR#2296, 428FE, IRS(sold) FFR Daytona Coupe under construction
I'm using the MSD Pro-Billet distributor, and the expansion tank came from Finish Line. This is my second tank. The first one I bought as a kit and after assembly, it did rest against the distributor cap. I ground the edge for clearance and caused a leak. I then purchased an assembled tank, which fit further to the passenger side, however, I still am unable to rotate the distributor. If the lip around the tank can be bent slightly,then that will solve the problem. Hope that helps.
