Old 02-10-2003, 09:32 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Cool Have the Richmond 6 speed overdrive
With 3.00 rear end gear set. 1st is usable only just off the line, and you need 2nd gear FAST. Do be careful not to go with a low rear end ratio with these transmissions, as you have 6 speeds to work with, and 1st and 2nd ratios in the tranny are usually low enough all by their lonesomes.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
