Old 02-10-2003, 08:58 PM
SCOBRAC's Avatar
SCOBRAC SCOBRAC is offline
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
The center punch holes are a way to secure the cork gaskets from squeezing out from betewwn the intake and the block as they will tend to do.. Many builders simply use RTV to mate the surfaces to not deal with the problem at all.. Either way you go you should use RTV where the surfaces come together from the manifold and heads to the block and anywhere oil may migrate from the heads to the block (at the top of the head/block surface under the valve cover gasket) and be sure to trim off any additional intake gasket where it protrudes from the head into the plane of the valve cover gasket..
As for the nicks.. I can't imagine why those would be there enless that is a trademark for those keepers.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
