Thread: willow springs
Old 02-12-2003, 08:13 AM
coyled coyled is offline
Dave, in the 17's you have a wide choice of good street tires that can work at the track also. I am running 15's so I am do not know which brands or sizes. You want 4 inches at the frame rails for clearance on the street. I am running the wilwood 12.2 4 piston superlites in front with the zo6 style single piston pbr's in back. The cobra stops well with these. Springs and sway bars and shocks are trial and error. I would try to get adjustable shocks and sway bars if I had it to do over again. You only need a steel bell housing if you gernade the clutch, I have one. Good luck, as a lot of this is trial and error. Scott
