Thread: Which Oil Pan
Old 02-12-2003, 02:49 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
since there is no crossmamber under you oil pan, you really only need worry about depth, you could even get a full length pan if you choose. Are you experiencing oil pressure flutter in the long sweeping turns? Do you have a windage screen that was properly fitted to the rotating assembly?
