Thread: Brake Questions
Old 02-12-2003, 03:12 PM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
cs69r, If the rear brakes are drum then you can use the stock Mustang II manual brake master. It will work with the Wilwoods. If you have the stock Mustang rear disc then as DV said I use a corvette master, but I don't think they make a Corvette master for manual brakes.
Jimp, the size of the reservoir really doesn't have much to do with the ability of the master to handle rear disc. It's the internals of the master that make the difference. You really aren't moving much fluid with a brake system adjusted properly. Discs tend to take less fluid since they are riding so close to the rotor. The master sets up the proper volume and pressure to the entire system.
Don
