Old 02-17-2003, 05:34 PM
Carroll DeWeese Carroll DeWeese is offline
What do you want the car to do? The key is not the strongest frame but a frame that can handle the loads placed upon it. You need a frame that is strong enough and that is in balance with the rest of the car. If you wnat original, it will not be as strong as some of the replica frames. Some replica frames look stronger but allow more twisting than others. Determine you budget. Find the replica that fits your budget and best meets your needs. Then make sure that the frame and other parts are adequate for you purposes. If the frame and other parts are inadequate, eliminate it from consideration. Do not pick a car for its frame and sacrifice other features.
