Thread: Oil leak ?
Old 02-23-2003, 09:29 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Lightbulb Do you have a working PCV system ?
I installed billet breather/PCV caps, but did not hook up the PCV part.. guess what happened ? The slight crankcase pressure forced a small amount of oil constantly out of the dipstick top, and made a mess down the driver's side undercarriage.. I discovered the source quickly and pulled the breathers until I can get the PCV hooked up this week.. Have foam in the grommets now to keep dirt out .... look ma, no leaks!
By the way, if your Breather rubber grommet is loose in the valve cover, get O rings that are sized to pop into the groove and make up the slack.. on my 514 this was perfect, and now no seepage there either.. I even used one on my hard rubber oil filler cap. tight fit, and perfect now.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
