Old 02-24-2003, 05:32 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Brent,
The bell housing should bolt up as they are both Fe blocks and essentially the same. If you get the flywheel with the 390 I would think it would be ok but some of the other guy's that know more can help you with that. I once changed out a 390 to a 427 tunnel port and my 4 speed bell housing bolted right up to it. I did change the flywheel as the tunnel port had one already on it from the builder and never had any balance problems.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
