Old 02-24-2003, 04:38 AM
Hal Copple Hal Copple is offline
Cobra Make, Engine: Superformance, 396 CI
Hello Jerry: i couldn't quite follow your thread, but then again i just got up.
My car has the ring bolts, the ones that come with the Simpson set, or you can buy at any racing place, they are mounted thru the floor at the rear-sides of each seat: my seatbelts have a webbing that goes thru a snap fitting, i just snap the belts in, and occasionally out to clean them, or replace them. They come with steel plates, with a matching hole drilled in the middle, so you can mount the ring bolts with the backing plate, so they don't pull thru thin metal or fiberglass. On my particular car there is a steel strap under the fiberglass just for this purpose.
For the shoulder belts, on my car there is a pre-made slit and cut in the rear bulkhead, the webbing attachment then slips thru there, then bolts with an ARP bolt thru the frame. I mounted my crotch strap to to the floor, thru a steel plate under the floor.
There are other ways to do the sholder belt thing, too.
But several years ago, i just decided i would always put it all on, every time i drive the car, properly adjusted. A minor accident would put my face right into the metal steering wheel hub.
While this might improve my looks, it would mess up the Momo.
If you want any digital pictures, just let me know,
Wear it all, ya'all.
Hal Copple
Stroked SPF
"Daily Driver"
IV Corps 71-72, Gulf War
