Old 02-25-2003, 11:52 AM
Clois Harlan's Avatar
Clois Harlan Clois Harlan is offline
Default Be sure.....
kiknasp,
I too originally went with a 302 but I would certainly suggest going with a late model 351 windsor instead. This way you will get most of the goodies (roller cam, roller rockers, etc. Also, do the math for your rear end gears. Unless you are running a Toploader transmission you will absolutely want 3:73 gears. I chose to go with a 428 CJ last year and I really like the torque but for a toploader I am geared to low (I am giving up top end speed). On your tires you need to talk to some people because there is NO selection in a performance tire in a 15". I am running 295-50-15 and 235-60-15 front and the rubber compound is way to hard, you can't get a speed rated 15" tire. Your wheels are one of your most expensive investments outside your engine so be sure you really want 15" wheels.
Clois Harlan
"Let's roll"
"Be part of Something Good
