Old 02-26-2003, 07:41 PM
R&B R&B is offline
Default Turn Signal Lights
Hi Bob,
I am just getting around to testing the lights. (I know I am way back in car number 574, but for some reason I seem to do everything at least three times.) Anyway everything seems to work except my left and right signal lights. A few months back I had a mishap with the ERA steering column trying to bend the lever back to make hand clearance. The lever popped off. I collected the springs (the ones I found) and I thought I put the column back correctly, but maybe not. Do you have any information I could use to recheck the steering column? The main wiring diagram has a note to “see separate sheet for ERA steering column”. Do you have a copy of this wiring diagram? Are there any other obvious reasons that may explain why the signal lights do not work? (By the way, I did check the fuse and changed the bulbs just in case.)
Thanks for you help.
