Old 02-28-2003, 01:36 AM
wilf leek's Avatar
wilf leek wilf leek is offline
Cobra Make, Engine: Crendon, windsor 408 stroker, tremec. Also GSX008
TomS - alternator bracket came from my engoine builder, will ask him for the source.
Plan now is:
stage 1: retorque all head bolts
if no cure:
stage 2: remove the 2 short bolts from around the affected area and refit with more sealant. Not doing this at stage one since I feel that completely removing any single bolt whilst the others are tight is intrinsically "bad" from a strict engineering viewpoint.
if no cure:
stage 3: pull head, check for straightness, replace cyl head gasket and use some luvverly silicon sealant.
Any particular grade of silicon I should be using? I have also heard that header gaskets seal better with that stuff.
Wilf
