Thread: Leaking Trans.
Old 02-28-2003, 04:46 AM
Ron61's Avatar
Ron61 Ron61 is offline
Post
Agro1,
I have the Borg Warner T-5 in my car and it takes me 20 minutes to have it out and on the ground. All I do is remove the shift handle, driveshaft, Tranny mounting plate, and then take the bolts loose on the front where it bolts to the housing. I take the bottom ones out first and then put a jack under it to hold it while I remove the top ones. If your's is easy to get to you should have no trouble taking it out and putting it back. Hopefully yours will be as easy to get to.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
