Thread: Leaking Trans.
Old 02-28-2003, 08:24 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Wilf has it right,
Tremecs have a little nub sticking down where the rear of the case meets the rest of the case, right at the parting line. I routinely would cut that off and grind it snooth. If you whack it hasd, it will cause a leak. They do not use gaskets, it's a red gooey non-hardening sealant.
