Old 03-03-2003, 10:25 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
First off, you don't need a choke with dual quads. Second, I would start by looking for a mechanical interference between the aircleaner assemblies and the carb. Have motor running and remove/install filters and their bases/lids. I haven't seen a 600 rpm idle change due to fuel mixture alone, it is an airflow issue. Maybe the lids are forcing the choke shut and getting you into fast idle cam territory.
