Thread: Why bother?
Old 03-05-2003, 07:55 PM
Pete Munroe Pete Munroe is offline
Cobra Make, Engine: ERA 289 FIA #2027, 65' 289" PS wheels
Default 302 vs. 351
I am using a 65' 289" block primarily because 5 years ago I thought I had to have a 65' or earlier block to squeeze through smog laws in California.
There is now a new bill in CA that allows 500 per year "kit cars", ie: you built it... vehicles to be registered as the year they were completed and meet the smog laws of the YEAR THEY REPRESENT!
Never in my life did I think anything good could come from Sacramento, the capitol of the left coast.
I am now a "built in 2002, smog exempt 1965 Cobra"...and the 65' block wasn't necessary. Arggggh!
That said, the 289/302 weighs a little less than a 351, and is about an inch lower profile.
I don't think the weight is 100 lbs less than a 351, more like 30?, but I may very well be wrong.
Can you guys check on real bare block weights....289-302 vs. 351 ?
So, with every bolt on item aluminum, I have a little lighter engine than the same in a 351, but probably not more than 50 pounds.
In a 289" car, I wanted handling over warp speed, so it will work for me untill I discover I am Ken Miles reincarnated...not likely!
The lower profile of the 289" lets me run a high rise and full 3 inch tall aircleaner without a hood scoop...I have a ERA 289 FIA, without the hood scoop, still room to spare, but a 351 high rise has to have the scoop I think..although with air horns shaved off a Holley maybe it would clear.
I am a little concerned about side loads on the block in theory, but I have a 6k chip in the MSD, and hope it's not a problem.
Time will tell!
If it blows in open track, I will try a 302 Sportsman block, or an unbored 302 if they are still available, whatever!!!
Have fun.
Pete
ERA 289 #2027
