Old 03-06-2003, 08:55 PM
Mark Husar Mark Husar is offline
Cobra Make, Engine: Compomotive. 351w, close ratio four speed, live axle, 4wdb.
FIA,
I bought a cobra that has a 396 small block. It was an exact duplicate of another engine that dyno'd out at just over500/500.
Build spec's:
Scat crank
Hbeam rods
10.5-1 pistons
Victor heads
750 holley
solid cam
I am not sure the piston spec's are right as I have compression ckecks at each cylinder of 285lbs.
Hope this helps.
P.S.: she lopes at low rpm but will but will pin your a$$ to the crack up to 6500 rpm. Haven't run it yet so don't have 1/4 times. To scary for me.
Tinman
