  #26 (permalink)
Old 03-07-2003, 06:04 AM
DAVID GAGNARD's Avatar
351-W, approx. 350 hp,Holley 600 vac. sec.,no choke, put gas pedal to the floor twice,hit the starter and she fires instantly,after oil pressure comes up to about 55/60 lbs. at 1000rpm idle I let out the clutch in reverse for about the length of the car,causing it to pull some vacum,after that she will idle just fine,usually let her warm up to at least 160 degrees before heading out.....
David
DAVID GAGNARD
