Old 03-08-2003, 05:57 PM
ENTDOC's Avatar
ENTDOC ENTDOC is offline
I found the neatest way to cut the pattern was with a dremel tool and reinforced cutting wheels.I then used a sanding wheel to radius the corners.I made my cuts vertical,however I would suggest using the Superperformance pattern as the back leg of the pattern allows more room for error in placing the pipes. chuck
